The WZ3500, Yup I said it......
  • The WZ3500, Yup I said it......
    Well since some now know since I popped by at the DRJ opener in Whitby I will get some pics and info up.
    Real quick note and will drop it; this was not the build my son and I were planning, twas to be turbo'd as well but, with the theft incedent, we just went NA. (for now)
    I must thank Andrew at Carcones, from Aurora Ont. I went online in search of a low mileage motor.
    Found this one with 11K only Emailed Carcones and then talked to Andrew.
    Told him what it was for and what I needed. I had asked him to leave as many connectors etc on the engine as possible.
    Well she turned up the next day with EVERYTHING!! I mean complete harness right to PCM and UBEC!.
    Great Price and AWESOME to deal with!!!
    I have more pics on my Camera, but will start with the Cell phone pics first.
    Engine clean up (not too much to do) and my son trying his hand at polishing.
    Polish engine mount bracket
    TCE Crank trigger that is needed for the 7X reference not on the 3500
    The main difference between the 3400 and the 3500 is not the displacement, it is the design of the heads/intake and manifolds!!
    Stock 200+ Hp
    All out ported 3800 heads still do not flow as well as stock 3500
    65mm TCE Throttle body to match the 65mm intake and flow
    Side by side comparison
    TCE Adjustable Fuel Pressure Regulator and GTP Injectors
    Of course we needed a better clutch so Bully 4 puck was installed
    As well need more fuel flow so a Walbro pump installed
    Lower engine mount made up and welded.
    and some final touches and clean ups
    Some how I ended up with the wrong trans lol, had one for Eco and not 2200 grrrrrrrrrrrrrr, my son and I spent a week cleaning and sanding and painting it, just to have to get a different one
    April1 10:30 pm, Darren cam by and we had engine out with in a few hours.
    Buy 2pm Friday, I was about to mate up engine and trans to find out wrong bellhousing lol.
    Darren located one and I sent him and my son out to retrieve it. (gave me about 5 hours to clear and clear coat every bolt I could find, I have a clear coat addiction, just ask Darren lol, even subframe bolts were cleaned and polished and cleared.
    Here she is in the engine bay
    Random pics
    MMMMM Brakes, ExtremeStop slotted and cross drilled rotors
    More pics to come as I get them off the Camera.
    Not sure if there is many other 3rd Gen J with a 3500 in it?
    Pics and links would be cool if you have any.
    Comments/Questions welcomed!
    As of April 2
    Engine: 2006 SV6 3500 LX9
    Trans: 2002 Getrag F23 5speed
    Injectors: #36 GTPs
    TB: 65mm TCE
    Maf: 1999 3400 Montana.
    Beverages: Ice Cold CANADIAN.
    Sorry about crappy cellphone vid and the second being sideways lol
    As of April 2
    Injectors: #36 GTPs
    TB: 65mm TCE
      One thing I actually really impressed with, NO WARNING LIGHTS
      All bulbs in cluster work but non illuminate.
      I kept ALL accessories including Airbags/Abs/Traction/Egr/EVap and even the Rear HO2S.
      Only codes Deleted were Trans and Passlock.
      Using a 2001 Imp 3400 Pcm
      And for FUN
      Lol, here is a pic of the GM Tech2 after I have been programming
      As of April 2
      Injectors: #36 GTPs
      TB: 65mm TCE
        any reason why you went with those exhaust manifolds? i think the malibus got the better ones... not sure about fitment though.
        otherwise, quite a damn project.
          Few reasons,
          Space & Fitment
          Project was to be Turbo, but that hasnt happened yet so I was (am) going to make some headers,
          Thanx.
          As of April 2
          Injectors: #36 GTPs
          TB: 65mm TCE
            Thats looking VERY clean and I can tell that youre not walking circles around obstacles.
            All I can say is im jealous and it looks SICK!
            Did your 3500 come with a forged crank?
            Originally posted by Mars
            Haha ^ Wrong Wheel Drive.
            No 60ºV6 at the moment
              To be honest I have NO idea.
              Never tore it down that much as it was practically new.
              Came from a 2006 Pontiac SV6.
              As of April 2
              Injectors: #36 GTPs
              TB: 65mm TCE
                This machine will kill be fast as hell I can feel ( and see it) LOL
                Mike 60degree addict.
                  A couple underneath pics,
                  I really need to fix the colour, going charcoal gray
                  Bulb test of cluster with Tech2, all lamps work, no bulbs removed
                  Running with NO warning lights
                  As of April 2
                  Injectors: #36 GTPs
                  TB: 65mm TCE
                    The only down side I see is unequal length axles. Other than that, that baby looks factory in there. Nice clean job on the install, man
                      Did you adjust the injector constant for the larger injectors?
                      That axle support looks out of adjustment... the axle is not coming out straight of the trans... The 3500 needs adjusting compared to bolting to the 3400 in that spot. Make sure that's aligned well.
                      The LX9 3500 (what you have) is 200 hp. The VVT one is the 220hp one.. Still in a J body that's like 2600lbs or something like that so it will haul ass. I can't wait until I get my house so I can put my cammed/headered/high-compression/3400-3500 in my orange car. I'm running a 92 282 getrag in that.
                        Ya, I made a mistake (so many nimbers going through my head) 200 not 220hp
                        I adjusted for the larger injectors, but they are pretty big for the moment, at WOT I max them @30%
                        But I am getting the tune there.
                        I spent quite some time measuring the axles, the pic doesn't do it justice.
                        The Trans is also in stock position.
                        Thanx guyz, she is a work in progresss for sure.
                        As of April 2
                        Injectors: #36 GTPs
                        TB: 65mm TCE
                          Wow, damn impressive man. i hope my build turns out looking that nice. i really shouldve went 3500 damnit all.
                          '96BerettaZ26- Med Adriatic Blue- FINALLY swapped '04 Impala 3400, Comp Cam, Comp 26986 springs, TCE lifter springs, WOTTECH Comp ported U&LIM, TCE 65MM TB, LM 4t60e~~~Looking for 3400 Downpipe
                            Isaac that picture the car is also at full extension of the suspension and not ride height so it will not be coming out level.
                              You all dont know what you're missing till you see this bad boy in action and up close n personal
                              ROB you rule buddeh! methinks i might make a trip out still n see what we can play with on the tuning while i get you to do a bit of work some Friday for me - how's that sound ? lol maybe get your son to polish my upper mount like that too
                              gawd i love ur 3500 - but i still love my 3400 too we should, when our cars are further along in power output setup/tuning, track them next yr @ the bash if avail? heads up
