Hello all 60*ers
  • Hello all 60*ers
    Guess I have been lurking enough and its time to say hi.
    I have been doing lots of reading and research here as I am planning to Boost a LX9 when I do the swap lol.
    Never worked with Bost before so I have lots of reading. (currently also readin Maximum Boost by Corky Bell)
    Lots of great info here as well as knowledgeable members I have found.
    Hope to be able to help out others as I have been helped.
    I am a little quiet on the exact details of my swap, as on most other forums I am on, I see so many plans and part piles that never get finished, I don't want to be one of those stats lol, so untill I am well underway with the work (and stop changing my mind and plans lol ) I will be quiet hehe.
    Great to be here!
    As of April 2
    Engine: 2006 SV6 3500 LX9
    Trans: 2002 Getrag F23 5speed
    Injectors: #36 GTPs
    TB: 65mm TCE
    Maf: 1999 3400 Montana.
    Beverages: Ice Cold CANADIAN.
    a good start to a great build. judging by all the questions you're asking, i'd say you're on the right track and as long as the funding and motivation stays, you'll have a fun car soon enough.
      Thanx, it does get abit overwhelming at times lol, but then I just need a beer and sit back and relax again.
      As of April 2
      Injectors: #36 GTPs
      TB: 65mm TCE
        Well, the other day I was razzin someone cuz they had no pics.
        Though I have not really discussed my build, I figured I should show a few pics.
        Hard to take pics as all the piecess are so shiny lol.
        3400 Throttle plate compared to the 65mm TCE beauty
        TB installed (the whole engine is just tacked together at this point, will come apart for final cleaning etc)
        Crank Trigger
        AFPR
        Couple Random
        As of April 2
        Injectors: #36 GTPs
        TB: 65mm TCE
          i know that sight... nastified TB plate...
            Yes the old Plate was disgusting!
            It did NOT come of my engine though, came from an Old Venture vaan here as I needed the Shaft.
            As of April 2
            Injectors: #36 GTPs
            TB: 65mm TCE
              Interesting design on the plenum. Did you sand the top, then paint it?
                Don't forget the locktite on the crank trigger!!
                Just trust me!
                  That is my sons work (he is 14) he used a scotchbright pad to smooth the top out, then painted it, then wet sanded 400 to 2000(raised areas), then painted it. then started the wet sanding again then clear coated it.
                  He did the upper mount bracket as well.
                  He is enjoying it and it keeps him off the streets lol.
                  As of April 2
                  Injectors: #36 GTPs
                  TB: 65mm TCE
                    Pics of something else that showed up today
                    As of April 2
                    Injectors: #36 GTPs
                    TB: 65mm TCE
                      Injectors should be here tomorrow, almost done with the wire Harness, so will be able to tuck the wires away and button up the engine!!!!
                      $0 more days till Install begins.
                      As of April 2
                      Injectors: #36 GTPs
                      TB: 65mm TCE
                        Anyone know where that light green wire goes?
                        LOL
                        JK
                        As of April 2
                        Injectors: #36 GTPs
                        TB: 65mm TCE
                          LOL
                          JK
                          That's good stuff, lol. I would actually expect Robert(Isaar) to really look it up just to see what it's for, lol. I would but I'm way too beat to even think about it.
                            i considered it, but i am a bit colorblind and i see about 20 "green" wires minimum.
                              Yeah, but there should only be one "light green", which would be easy to spot on a wiring diagram At least I was partially right, lol.
