racing v6 class
  • racing v6 class
    hi we are racing dirt track need to up performance we have a f word walking away from us we want to do rocker up grade need pros and cons of up grade
    Welcome. We need to know what engine you are working with before we can provide you with any suggestions.
      sorry forgot to include that 3.1 v6 from 92 corsica thats what we are running
        Ok, that helps out. Now, the next question - what are the rules for the class you are running? Does the engine have to remain "stock", hence the reason you are looking into rockers as an upgrade option?
          yes say stock apearing no computer mods no cold air intake stuff like that
            i was reading on here about 3100 rockers being 1.6 i was told that it would wake up my performance on my 3.1 i am just wondering if im going to run into other issues
              Probably the cheapest thing you could do is go with rockers from a 94-95 3100 (3.1L). They are 1.6 ratio versus your 1.5 ratio, and are direct replacements for what you have. That would give you a slight increase in lift on the intake and exhaust side, which will net you some power. Another item that would be good to replace, if possible, would be the stock downpipe. The downpipes on these cars are usually a dual-pipe setup, therefore the internal diameter is much smaller than it appears from the outside. By upgrading the downpipe, you will see some gains in power as well, since you are opening up the exhaust system.
                so what size down pipe should get it off different year car or same year i get rocckers from cause we have several 3100 just sittin on ground in friends junk yard but dont think any down pipes on them
                  There really isn't a stock replacement for them. It would most likely have to be a custom welded up exhaust pipe, which may not be possible for a "stock" class. There *might* be the possibility of gutting a stock one so that it is only a single tube, but it would still require welding in multiple areas.
                    exuast dont think it matters just has to be past the fire wall
                      computer mods(tuning) are pretty easy to hide.... should it become necessary
                        Well, the downpipe starts at the end of the exhaust manifold, so the first section of it could potentially be in front of the firewall... Would be something to look at and possibly question your organization about. Or just try it and hope they don't notice it!
                          all that is on now is the down pipe (stock)from manifold down to where cat used to be and thats it
                            as for computer mods they open and check proms for chevy numbers or other chips installed
                              hmmm.... do they take the blue plastic cover off?
