I have a vibration at 2000rpm
  • I have a vibration at 2000rpm
    is the engine internaly or externaly balance
    I have the same problem, but it stops when I take the key out
    sorry just kidding..
    sigpicWhen I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car.
      explain more...
        I have a vibraton at 2000rpms
        Just installed this into a jeep. Threw on the flywheel and a new clutch. Now under load or foot to the floor no knock or vibration. Idle no noises. Cruzing speed noisy, step on it goes away, comes back when backing off the throttle and maintaining speed.
          ok, how about exactly what motor it is? 2.8?
          and what kind of clutch, like a stage 4 Spec? because the badass race clutches will chatter when not under a lot of load...
            We need to know what engine this is to give you advice...
              we do need more info, but check your u-joints, sounds like you got a stiff one. If you feel it through the truck too that may be it. And or, not very common, but likely since you've had it apart, check the alignment between the trans to the motor, sometimes corrosion will cause the bellhousing to swell where it attachs to the motor and it may look tight and square but its not. That misalignment will cause a chatter in the driveline too.
                have you had the drive line out? if so you could have put it in upside down. they have weights on them for a reason. its just a thought tho!
