OBD1 vs OBD2
  • OBD1 vs OBD2
    Which is better to work with on a 97 motor. Which is easier to reprogram for use with a manual. Also is a Haltech an even better choice?
    The dhp tuner is vary vary easy to work with.
      OBD2. Haltech is good, but I honestly would probably prefer DHP or HPTuners to Haltech. There are some other good standalones that I would consider, but they are $$$$.
      Tim
      325 whp 350 lb-ft
        Thrid vote for DHP
        wow all three DOHC Powertuner owners in the same thread! you still have your PT right timg?
          Yup. Still have it. I got the interface registered, but am having trouble connecting to the ECU.
          Tim
          325 whp 350 lb-ft
            probably a driver or something
              Nah, it's an error 150. It's communicating with the PowerTuner box, but not the PCM itself. I think it's an issue with the wiring. Right now, my engine, wiring harness, and pcm are all on an engine stand and I'm trying to communicate through the C100/OBD2 connector... The Powertuner is getting power, but it doesn't seem to be able to talk with the pcm.
              Tim
              325 whp 350 lb-ft
                Well now you can add the only DOHC HPTuners tuner. I'm happy with its performance. Aftermarket forces you to start from scratch, OBD II at least gives you a base. It's not terribly hard to make it work with a manual, takes a little computer trickery, but it works.
