I'm going for it. 4 exhaust cams!! :)
  • #46
    Ok folks I'm back from Michigan. Took my car out for a drive for the first time since I returned. Went to Domino's pizza to pick up pizza's. When I came out to leave, car wouldn't start. &$*&$^%!!! Dam!! Well at least I wasn't hungry while I waited for bro to come tow me home. Fuel pump went out. Delphi fuel pump was 340.00 dollars!!! Couldn't find a cheaper one. This thing is a fuel pump module is what the call it. Has sending unit and a fuel resevior canister built together. That was my dyno fund.. ;(
    Dyno run will have to what until next payday.
    1997 Z34 Monte,: testing 4 exh cam\'s, RSM STB, K&N, Eagle077 245/40/ZR18 Nitto Extreme
    • #47
      damn dude, a walbro 255lph is a little over 100 bux
      • #48
        I wish it was that simple. Seems GM changed fuel pump designs in 97, to this. They added this little line to it. From what I can tell it pulsates a small pump in the bottom of res. canister. Theres also a float in the bottom of canister. If you notice there is also 2 fuel socks. One one the bottom of res. can and one on bottom of pump it self.
        • #49
          Sucks dude... Any way to back-convert to the "old" style tank module? Or is the lock-cover a different size and shape?
          • #50
            Would have to change the complete tank. theres no baffle in te bottom of this tank like the older onees.
            • #51
              you shouldnt have to replace the entire pickup assembly unless you broke something. the fuel pump just pops right out and you can put a walbro in it with no problems. I just got done doing it with my car b/c my pump couldnt keep up with a l67.
              1st 04 GPG 88-96 mod car show
              L67 Swap, 3.25, XP'd, Custom Headers, 180 tstat, AL103's, 7" K+N, AFC2.2, Rat UDWP & Alt, Walbro,Taylor wires
              N* TB & HP Ported Blower
              PB-13.3@102mph
              http://www.SleeperSe.com
              http://wbodysource.com
              • #52
                Hope it gets fixed soon. Need those dyno #s.
                • #53
                  Any luck?
                  • #54
                    Ok guys here's the results! 1997 Monte Carlo 117k miles all stock, except K&N air filter, 4 exhaust cams -4 degrees exhaust and +4 degrees intake. Known bad exhaust guide. ;(
                    MAX Wheel HP=172.4 MAX Wheel TQ=155.9
                    • #55
                      I don't suppose you did a before and after the timing?
                      Good HP numbers for having no mods. But the torque needs some help I'll admit.
                      1999 SVT Lightning
                      1996 Monte Z34 R.I.P.
                      Next BEATER: a C5
                      http://www.fquick.com/ez112
                      • #56
                        Basically stock overall horsepower, less torque...
                        But completely flat across the band... And makes power to 7k...
                        Impressive. I can see this making more of a difference in a Fiero. Interesting.
                        Thanks for posting it!
                        • #57
                          It made power right up until it hit the rev limiter. Not sure of the % of loss through an automatic trans is.
                          • #58
                            You can gain back some of the lost HP from the AT by switching to Ford Fluid. Sharper shifts. I've used it for....forever. Usually my first "mod" on a GM product.
                            And thanx for the Dyno info. Me may go that way. If it doesn't work, I can always go back.
                            • #59
                              It works been running it for over 2 years. Pain in the ass to time!!
                              • #60
                                A.K.A you your_I.D. here........... Haven't been around in awhile. New wife and stepdaughter, took over my life. Car has been parked for a couple year's. I'm back!! Sold mycar to a 16 year old family friend. The whole 4 exh cam exp. wasn't worth the extra power increase. It moved the power banned way to high to be usefull on the street. somebody had to try it. Pulling the heads off for a V Job and putting stock cams back in it.
