Lowering and Handling
  • Lowering and Handling
    Hey, I have a 93 z34 my name is joel for those who dont know. I kow that ffp makes a coil over kit for the back to replace the mono leaf but is there a way to get beter springs that also lower the car with out going this way. I like the mono leaf it seems to handle well and also to put the coil overs in it cost like 600 or somewhere up there. tell me if i am wrong but you can use monte front springs but is there another way or spring for the rear.
    Thanks
    also lol, I want to possible make or buy a rear sway bar. are there any designs out there and what would be the best materials to use.
    Thanks again
    Joel
      your gonna have to search around to figure out how to lower with a mono leaf. as far as a sway bar, unless you have a machine to bend a spring steel rod on then you'd be better off grabbing a torsion bar from another vehical, and fabbing up some mounts, and some arms, similar to stuff you see in the jegs catalogs.
        I already moved your original post to the SUSPENSION area where it belongs. So look there for replies.
