96-97 Cam Retard
  • 96-97 Cam Retard
    Hello
    Has anyone done the exhaust retard on the 96 or 97's yet, If so how does it work with an Automatic Trans?
    Thanks in advance
    John
    Werent all the 96/97s automatic anyways?
    New member of 200,000 mile club as of May 16, 2005
      Hello
      Don't know about that, but mine is an automatic, I have seen some post's that talk about standard transmissions and automatics, thats why I asked about the automatic.
      John
        They are all automatics. You would have to experiment with the cam timing, but do not run 13 degrees retarded on it as the stock exhaust cam is already 3 or 4 degrees retarded compared to 91-95 I believe. Intake is advanced in comparison as well. Being an automatic doesn't mean that changing the cam timing won't be beneficial, though I would consider more advance on the intake and a little more retard on the exhaust. Ill know what that cam timing does on the 91-95 in the next few days.
          Tried out my new cam timing tool today.
          A major improvement on the bottom end!!
          Assuming there is a factory +4 int & -4 exh. already set from factory.
          My settings by the new cam tool:
          intake +2 (which is +4 crank degrees) then add in the factory +4 = +8 total
          exhaust -2 (which is -4 crank degrees) then add in the factory -4 = -8 total
          So: +8 intake
          -8 exhaust
          Correct if im wrong.
          1997 Z34 Monte,: testing 4 exh cam\'s, RSM STB, K&N, Eagle077 245/40/ZR18 Nitto Extreme
            So: +8 intake
            -8 exhaust
            So is this the best setup for 96-97 3.4 DOHC automatics? Thanks
              this thread is from 2005... you probably wont get a response.
                Well since 60v6 isn't a flame pit like most forums, you never know
