12 sec NA DOHC n a Fiero possible? Yes..Will has done it with his N* (Oh..sorry....you meant 3.4 DOHC
The guy with the LT-1/4spd was grenading suspect mileage '84 units with the weaker case, and there is some question as to the eccentricity of his adapter plate. There are also lots of people blowing the diffs out of high-mileage Getrags, most likely with worn diff bearings. If he had tried a freshened later V6 4-spd with the stronger case he might not have the same problems. For all the people blowing up transmissions, there are just as many high HP/Trq Fieros running hard without breaking the trans.
The DOHC that put 240 HP to the wheels had custom headers, short runner/large plenum intake manifold, degreed cams, and shimmed valve springs. The owner admitted it wasn't a very streetable package due to the torque loss down low.
The Northstar pistons sound good at face value, with the 93mm bore, but the piston pin diameter and the compression height are different. 6" rods will put the piston top 0.076" above the deck surface, which won't work. Most likely custom rods would be required. Just because they make 10.3:1 compression in the N* doesn't mean it will yield the same in a 3.4 DOHC. You would be better off getting custom 93mm forged pistons made to your desired compression ratio.
As far as the most modded NA DOHC being Aaron's? What a joke.
If I ever go with a 3.4 DOHC in my Fiero, it will have a turbo. You can do it NA, but its just too much $$ and work. Without variable valve timing or dual-runner intake, the engine is handicapped.
Marty
Marty
