Transmissions for the 96 Olds cutlass 3.4L DOHC
  • Transmissions for the 96 Olds cutlass 3.4L DOHC
    Just curious if the 4T85HD Trans out of the 3.8 ssei would bolt up to the 3.4L Dohc, if not what would?
    no FWD 3.8 got anything tougher than a 4t65e-HD...
      So what will bolt up to the 3.4 DOHC, need something that can take a beating
        4t65-eHD should hold up, or if you really want to make your car heavy, 4T80-E from the caddy's.... (not sure about the bolt pattern)
        Or a getrag 284/282 5spd...
          I was told the 4t65-eHD doesnt have the same bolt pattern, please let me know if it does and what model cars these came in
            It does. The 60V6s and 3800 share the same bolt pattern.
              4t80e has a slightly different bolt pattern, but they are damn near indestructible. so if it's necessary, it may be the only option.
                What's the breaking point of one?
                  AFAIK: i've NEVER seens a broken 4t80e.....
                  how's that for a breaking point?
                    Yeah but does anyone with heavily modified engines/high horsepower run these?
                      the 300lbs of torque a NS makes in a heavy ass car seems like punishment to me.
                      it would be a cakewalk for L/J/N bodies. W is a bit closer to most caddies, but still...
                        A 4T65-HD will bolt up fine to the engine. LQ1 cars use a different tranny mount so I'm not sure if it can be bolted to the engine cradle. Also I think the axles won't fit in a 1st gen hub though. It's electronics are also way different, so your LQ1 PCM won't be able to control it.
                        It's found in anything with a Series II or III Supercharged 3800. Regal GS, Grand Prix GTP, Park Avenue Ultra, Monte SS Supercharged are the ones I can think of.
                        Jesse M.
                        3x 1990 Turbo Grand Prix
                        1987 Monte Carlo SS Aerocoupe
                          I have a 96 olds Cutlass supreme, 3.4L DOHC and would like to basically know what besides the 4t60e works, I am about done with my second trans in less than 30,000 miles, I NEED something that can take the abuse and isnt that hard to convert
                            if you have the ability to tune it, you can stick the PCM from a 97 3.4 in it. those work with 4t65-e and 4t65-e HD...
                            why exactly are the trannies dying?
                              AS for the Getrag, I keep hearing so much about.... Where the hell do I find one?? I have searched the net high and low
