OBDII Swap?
  • OBDII Swap?
    Whats the going rate for a '96 Harness, DL port and ecu? trying to decide if its worth going back to the JY and pulling the Engine harness? i have the ECU already....
    S
    Shane "RedZMonte"
    1992 Lumina Z34-VIRGIN (RIP)
    1992 L67 Lumina Z34 (SOLD)
    1990 Turbo Grand Prix (SOLD)
    Im on the same boat as you.. I am trying to get a parts car though so i dont have to remove it out of the yard if it comes to that.. even if there are any 96/97 3.4'd in there which its really scarse..
    Robert
    New Rebuilt 3100
    New Rebuilt 4T60-E
    Exhaust
    Drilled/Slotted Rotors
    White
    3" Magnaflow Catback
    90 Pontiac Turbo Grand Prix
    5 Speed Swapped
    127,000
    Spec Stage 3 Clutch
    230,000 mile Getrag 282
    Emissions Deleted
    Brand new Engine 1,000 Miles
    Fully Custom Built car
      when we pulled all the stuff needed to OBD-II swap a beretta i think it ran a little over 100 bucks.
      this was with the Abs/fluid res too so overall price without it would be cheaper.
      these are rough prices from when i got the stuff myself
      engine harness was $40
      ecu about $30
      DL port most of the time a freebie.
      the engine harness was expensive its just a little time consuming to remove.
      99 Grand Am GT
      1357 cam 227 233 .050 dur
      515 515 lift 112 lsa
        yeah, ive done the swap on my car so i know how much of a PITA it is.. I am only thinking about it caus i have everything up top allready off (from snagging the intakes) so most of it is allready off.. just have to get the parts off that suck the worst lol... i think i payed about $150 for my ecu/harness when i bought mine from car-part.com and had it shipped (much easier that way lol).. but if they where going for like $150 on the board i would consider pulling the harness out and selling it, helps someone out and maybe make a couple $$ for my time.. It is on a '96 Z34 so it is a good JY find, i wasnt planning on doing a intake swap but kind of just fell into my lap so i figured what the hell.
        S
        Shane "RedZMonte"
          S
          Well im on the market for 96/97 3.4 parts.. Im currently going to be in the process of 5 spd swapping my 95 and i want to put the 96/97 motor and OBD2 the car.. So i dont know what the prices are for the engine harness and computer i will be intrested.. See what you can get them for.. I also need the throttle cable from the pedal to the throttle body.. See what you come up with..
          Robert
          New Rebuilt 3100
          New Rebuilt 4T60-E
          Exhaust
          White
          5 Speed Swapped
          127,000
          Spec Stage 3 Clutch
          Emissions Deleted
            nvm i have a lead on a motor computer and harness
            Robert
            New Rebuilt 3100
            New Rebuilt 4T60-E
            Exhaust
            White
            5 Speed Swapped
            127,000
            Spec Stage 3 Clutch
            Emissions Deleted
              S
              I did my OBDII swap last year in 2008. I paid $14.99 for the wiring harness and $19.99 for the PCM. The $14.99 also included all the sensors that needed to be switched over.
                Woa.. can you get another 96 PCM?
                Robert
                New Rebuilt 3100
                New Rebuilt 4T60-E
                Exhaust
                White
                5 Speed Swapped
                127,000
                Spec Stage 3 Clutch
                Emissions Deleted
                  They are rare to come by in this yard I goto. I usually go and check once in a while, but there hasn't been any lately.
                    There was a PCM at the yard I was at.
