Royal Purple Syncromax
  • #16
    Another question is: Can you use anyhting other than the GM Syncromesh or Royal Purple SyncroMax? Can an 85W140 weight or 75W90 or synthetic 75W90?
    sigpic1993 Pontiac Grand Prix SE, 3.4L DOHC 24 Valve V6 MFPI, 5 speed, completely stock, bucket on a budget!
    • #17
      If you want....
      1991 Grand Prix STE
      3.4 DOHC
      1 of 792 Produced
      Extensive Mods Done
      1991 Lumina Z34
      3.4 DOHC
      Getrag 284 5spd
      1 of 30
      • #18
        I just don't want to damage my gear box or seals in it. I know some gear boxes are very finicky about the type of oil you use in the gear box. So would a heavy 85W140 work fine or a light 75W90?
        • #19
          The Synchromesh is a lot lighter then gear lube. Gear lube is for differentials and outboards. Even my truck doesn't use gear lube in the transmission, it uses dexron, lol.
          • #20
            75W-90 was the original wieght, but I would go with a synchromesh fluid if your re-filling it.......
            You won't believe how much smoother it shifts.....
            1991 Grand Prix STE
            3.4 DOHC
            1 of 792 Produced
            Extensive Mods Done
            1991 Lumina Z34
            3.4 DOHC
            Getrag 284 5spd
            1 of 30
            • #21
              i saw an episode on HPTV once in which they dyno'd i believe it was a camaro before & after with royal purple fluids & gained like 3-4 whp. impressive but who knows how god-awful the fluids that had been in it were...
              they also prolly spent $100+ on all the different fluids because that crap is expensive!!
              • #22
                Well, I think I'm going to go with the Royal Purple SyncroMax because I used conventional oils in my old Subaru and when I changed to Royal Purple, the car ran totally different, was a lot smoother, idled smoother, and acceleration got a little too peppy. That was only driving it after 100 miles or so. I think the additives coat micro-fissures and cracks in the block....who knows? Cause I know my Suby had a lot of blow-by and it stopped after RP.
