mods for DOHC
  • mods for DOHC
    I have a lumina z34 with a straight pipe as far as I know for mods wat other small things coukd I do to gain more power n e help iz appreciated
    moved to the right section and changed the title to something meaningful.
    What year is your car?
      As far as bolt ons go there are a few options. Easy stuff would be an intake of some sort, and full exhaust system - 2.5" is the generally accepted size for most 3.4 dohc applications. The WOT-Tech store sells a few things including a reprogrammed chip (91-93 years).
      The 96/97 intake manifolds flow better and can be considered a bolt on upgrade though they do involve a good bit of wrenching experience and some custom work. Not for the newbie but also not the most difficult thing either.
      There are more than a few threads on cam timing. Different setting can bump power a bit and change the powerband. Again, if you don't have much experience this may be a bit overwhelming to tackle.
      Other than that you're looking at things that require much more experience/money: head work, valvetrain and internal engine upgrades.
      If you're new at this, start with maintainance. Maybe task yourself with changing the timing belt and doing a tuneup to get to know the engine better. You can even 'gain' power by reclaiming power lost to a worn out / out of time belt.
      1994 Corvette
      LT1/ZF6
      2006 Dodge Dakota 4x4
      3.7/42RLE
        Thanks alot for the help.I have a 93 chevrolet lumina z34.About the the diffrent air intakes does it matter wich one i get??or do they all do the same thing and give the same horsepower.also does taking out the hood vent filter things off does it give more air flow also??thanx if u can help
          As far as I know most people make their own. HP gain from an intake alone... I dunno 3. Maybe.
          From your other posts it looks like you are trying to find a magic bullet to make your car a lot more powerful and it doesn't exist. It takes time, experience and money to do it right. Not to say bolt-ons are worthless but they are few and far between for this motor.
          If you're having trouble handing a corolla its ass then I'd go out on a limb and say your car is in piss poor shape. A bone stock 3.4dohc with an auto trans should run in the 15 second range if its in good shape. I don't know what a corolla can do but I imagine even any sport model they have is stuck in 16+ second territory.
          1994 Corvette
          LT1/ZF6
          3.7/42RLE
            Lol no its in good shape i keep up the maintenance on changing the oil also adding lucas for a little better performance and engine wear protection.the engine runs VERY strong i
            have not lost a race yet and i have not yet raced the corolla because he says its a waist of time.n e wayz i know it takes time to make a fast car im just trying to get as much info about the diffrent things i can do.but again car is in great condition.not being totally stock with a straight pipe,air intake and automatic shift kit.
