Deleting evap and pcv
  • #16
    I Forgot to mention......
    For any that are going to be running a vacuum pump, make sure the seal on the oil cap is good and the O-rings on the dipstick are excellent (Or just put New ones there cheap)
    Also, Have the bleed of valves set to between 10"Hg-14"Hg of Vacuum, You can experiment in that range, If your sucking up a pile of oil to the catch can bleed off more pressure.
    Moroso sells the bleed off valves, there# 22637 (3/4"), 22636 (3/8") and one that mounts on the line to the pump is # 22633
    1991 Grand Prix STE
    3.4 DOHC
    1 of 792 Produced
    Extensive Mods Done
    1991 Lumina Z34
    3.4 DOHC
    Getrag 284 5spd
    1 of 30
    • #17
      Dry Sump systems can run as high as 22" Hg of Vacuum, ...IF... that is your set up.
      Even small amounts of Vacuum STILL have its benifits.
      1991 Grand Prix STE
      3.4 DOHC
      1 of 792 Produced
      Extensive Mods Done
      1991 Lumina Z34
      3.4 DOHC
      Getrag 284 5spd
      1 of 30
      • #18
        I know this is an old thread, but I just had a question about adding an electric pump.
        I've seen the ones they sell for $300, but I was wondering if something like this would work?: http://www.sparkfun.com/products/10398
        • #19
          I actually did run an electric pump for some time. The reason I did it is because my old motor began to wear out and the rings didn't seal so well anymore at wide open throttle and I would get some smoke out the pipes caused as a byproduct of blowby.
          I ended up using an electric smog pump off an Fbody car to pull the extra gasses out of the crankcase. I used an air/oil separator inline to keep most of the oil out of the pump. I routed the output side of the pump into evac tubes in the exhaust pipes that I welded in just after the mufflers (and just before the exaust tips).
          I went the extra step of modifying the bin that the ecm used. I changed it so that the economy shift light would just come on right at 4k rpm and stay on at any rpm above that speed. I used the output on the ecm for the shift light to energize a relay for the pump. So, anytime the rpm exceeded 4k rpm the pump would come on and evacuate the crankcase.
          It controlled blowby well enough that I would not puff smoke at WOT.
          I abandoned the setup when I swapped in the new motor. I still have it though. I can locate all the parts and if your interested we can work something out.
          1994 Corvette
          LT1/ZF6
          2006 Dodge Dakota 4x4
          3.7/42RLE
