Fuel Pumps
  • Fuel Pumps
    Any idea what fuel pumps can be swapped in to my stock housing without any issues?
    I am looking to upgrade the fuel system in anticipation of more requirements for my engine build.
    Any suggestions?
    Corvette? Truck etc?
    I dont know what this means but "ASS HATS" is funny
    I got a some listed in some of the aftermarket catalogs I have Shawn.
    If your off work let me know cause you can just look through the catalogs yourself if you want and you can see the new show room and waiting room I've made.....
    1991 Grand Prix STE
    3.4 DOHC
    1 of 792 Produced
    Extensive Mods Done
    1991 Lumina Z34
    3.4 DOHC
    Getrag 284 5spd
    1 of 30
      Will do David. Thanks
        Ive been told you will need larger injectors, better fpr and a good tune if you upgrade the pump. I dont think its really worth it unless your running boost.
          I agree with you on the upgrades only required if you are running boost.............
            Walbro 255HP
            Tim
            325 whp 350 lb-ft
              Walbro 255HP
              Tim
              walbros are all universal types? requires modifications? any pictures installed?
                all/Most GM fuel pumps are the same dimentions. I also have a Walbro 255LPH... It fits in exactly like the stock pump. just be carefull when installing it not to bend the float or your fuel guage will be off. i ran the 255lph HP (high Pressure) because i had a FMU that jacks the fuel pressure way up and the HP will not fall off as much as the 255 standard. it fits but the inlet to the fuel pump is much larger...shes a tight fit.
                just get one for a Camaro or corvette. it is the same plugs and what not.
                S
                Shane "RedZMonte"
                1992 Lumina Z34-VIRGIN (RIP)
                1992 L67 Lumina Z34 (SOLD)
                1990 Turbo Grand Prix (SOLD)
                  S
                  you got a part number for the corvette one?
                  i suppose getting it from the dealer would be the best?
                  thanks for your input.
                    AC Delco fuel pump at Summit
                    Summit has a large list of Delco pumps for sale. That one is pretty cheap and has Corvette as well as many fullsize pickups listed for direct replacement.
                    I'm not totally sure which ones they have that will definitely fit, but I have heard that the ones from a Camaro or Corvette will fit in a W-body and other applications. Judging by the amount of pumps they have available I'm certain they have something that fits. Plus it's an AC Delco, so you don't have to worry about reliability!
                      I have a Corvette LT1 fuel pump in my garage, you can have it for $30 plus shipping...
                      I was going to use it untill I got a killer deal on an Aeromotive A1000
                        Thanks for the offer FF I just want to be 100% sure I can swap them in fairly easy without destroying the sending unit.
                          Does anyone have a line on a part # for a Walboro 255 series Fuel pump that will fit my 96GTP?
                            Walbro GCA758-2
                            Sorry Shawn for the delay, I've been really sick these past couple days.
                            1991 Grand Prix STE
                            3.4 DOHC
                            1 of 792 Produced
                            Extensive Mods Done
                            1991 Lumina Z34
                            3.4 DOHC
                            Getrag 284 5spd
                            1 of 30
                              I know Dave thats why I wasnt buggin you.
