Wideband o2 sensor
  • Wideband o2 sensor
    To properly tune the engine with what I plan, I wanted to get an 02 sensor that read everything, not like the one i have right now which is more for show than to actually tune...
    What kind of 02 sensor would i need? Would a 4 wire sensor do or is it a special 02 sensor? ALso, saying I would get my hands on the 02 sensor, would I have to buy the special device that interprets the voltage signal or could I simply use the cheapy one I have for looks?(Air/Fuel Ratio Gauge)
    \"Pree\" - 93 Grand Prix SE - 3.4L Twin Dual Cam
    - FFP UD Pulley - FFP Chip - 8mm Taylor Wires
    - 160* T/stat - Dual 40 Series Flowmasters
    - Hi-Flo Cat
    15.2@95mph - GTECH P/B
    http://home.rgv.rr.com/tjperformance/Cap0005.mpg
    ... you'll need a wideband O2, check out http://www.aempower.com/product_ems.asp and look at their WEGO setup, it's the least expesnive (non diy setup) I've found anywhere.
    Dave ... Dave.45 ... DaveFromColorado ... it\'s all me.
      What I said on w-body, plus http://www.wbo2.com/
