plug the throttle body water coolant
  • plug the throttle body water coolant
    Hi has anyone pluged the hot water coolant that goes araound the throttle bodie and what is the best way.. becouse thats only to prevent the throttle from freazing and getting stuck in cold weather but here i dont have that problem and i think i can get a little more power gain and a bit better gas milage (here in europe with the high price of gas every drop counts hehe) since it wont heat up the air going in... its the 3.4 v6 92 lumina
    im only guessing it would do some differance cuz the throttle body realy get very hot
    thanxxxxx
    I know how to do it on the 96-97 TB's but never owned a 91-95 so im no help...
      you could take the upper intake manifold off and plug the TB passage with JB weld or similar. i have only done it on my 96 DOHC as well. but is should work.... as for gains... it wont be noticable. your better off porting and polishing the TB and intake manifold while you have it apart.
        theres really no need to plug it, just loop the coolant hose back to the other port, the throttle ports can be left open
          You could use a small freeze in one port or tap it and use a pipe plug. The hose can be plugged with just about anything that will fit. But you won't gain any fuel milage since the air going through the manifold will be cooler, and cooler air is denser than warm air. You shouldn't drop any milage
          68 El camino 454 speed muncie 3.90 posi 12 bolt,
          80 Monza Spyder nasty buick 231/3.8l v6 200-4R 3.73 posi.
          60 Impala 2 door hardtop L79-327 T56 4.11 posi.
          83 wagoneer torque pig AMC 360 hydradrive (gm turbo 400 with stock sb chrysler bellhousing boltpattern) dana 20 transfer case dana 60 front GM 14 bolt rear. 401 in the wokrs
          91 Z34 now has a hm284. and belly pan in the works
            i have an intake with that setup, when i get the chance i will take a look at it and let you know.
