Problems with the 3.4 TURBO-again
  • #46
    Are you not tuned already though? Could also be just the rrfpr adding too much fuel upon start up causing for a slight fouling of the plugs.
    If you're in of a tune, do it asap!
    • #47
      How can I do a tune on a obd 1.5. I have to do a obd II swap and get someone with an hp tuner do the tuning. I replace the FPR. I am adding the FMU back in with a 4.1 ratio
      • #48
        SOL with "1.5" time to move back to the better obd1 or goto obd2... Standalone works too!
        • #49
          I have been told the obd II is the best, so I will try and find the harness and go from there
          • #50
            http://dtcc.cz28.com/eprom/index.htm he can do 1.5
            Something cool coming soon...
            96 LQ1!
            • #51
              OMg thanks I will try them
              • #52
                Ryan at Sinister is the best LQ1 tuner I think I've ever come across.
                Getaway cars:
                1986 Fiero SE | 2.0 OHC Turbo/Intercooled | MT2 5 Speed - 1994 Dodge Stealth | 6G72 SOHC 12v | F4a33 - 1999 Ford Windstar | 3.8 Essex | AX4S -1998 Lexus SC400 | 4.0 DOHC 1UZ | A650E
                • #53
                  really, Well i think I am going to use him. Sounds like he knows like he is talking about
                  • #54
                    You have a bunch of money in that car. You should get at a minimum a wideband. And either a tuner for your PCM or a standalone.
                    1987 Fiero GT - 95' 3.4l DOHC LQ1, GT3071r turbo, intercooled, Haltech E6K, custom stainless headers and exhaust, Tial 38mm wastegate, 38 lb/hr MSD injectors, custom intake manifold, 12" 4-piston front brakes, 11.25" rear.
                    415 WHP, 11.92 @118 1/4, 28 MPG, on pump gas.
