Fuel lines
  • Fuel lines
    I am about to hook up my FMU. I know its not the best, but for now it should make the car run. So Is the bigger line or the smaller line the feed line. I am trying to figure out what is what.
    turn on the ignition and find out :P
    i think the larger one is the feed btw.
      For my Beretta the 3/8" is the feed and the 5/16" is the return. I think that goes for most 60*v6 fuel injected cars.
        remeber to hook the FMU to the return line. And make sure you also hook the FMU up properly. If i remember the FMU should be "In from the fuel rail to the Side" and "Out to the hard line from the Center". like SO:
        On the fuel rail the Larger line is the feed (rear line if your standing at the front of the car) and the smaller is the return (the line closest to the front of the car). I replaced my stock fuel line with a new rubber fuel line to run to the fmu and then also from the fmu to the hard return line. my feed line is the stock line.
        hope this helps.
        S
        Shane "RedZMonte"
        1992 Lumina Z34-VIRGIN (RIP)
        1992 L67 Lumina Z34 (SOLD)
        1990 Turbo Grand Prix (SOLD)
          awsome,thanks
            Bigger is always feed, smaller is always return.
