Will IROC fit Z34?
  • Will IROC fit Z34?
    Will the IROC Camero Wheels fit on the Z34 Lumina? I'm sorry but I get a hard on every time I see them.
    no i believe they will not.
      wrong offset and bolt pattern.
      GM FWD cars use a 5x115 bolt patter and a 25mm(TGP), 38mm(Z34, Grand Prix, Cutlass, ect..) or a 52mm (1997+ GTP, Regal, ect...) offset depending on model and year.
      The camaro is a 5x114.3/5x4.5 bolt pattern and a much lower offset. RWD offsets are much different then FWD offsets.
      So to answer the question no. Not a direct bolt on.
      Shane "RedZMonte"
      1992 Lumina Z34-VIRGIN (RIP)
      1992 L67 Lumina Z34 (SOLD)
      1990 Turbo Grand Prix (SOLD)
        The camaro has a 4 3/4 pattern, not a 4.5
          Don't S10s have the same bolt pattern as Camaros? I have seen crosslaces on an S10 already, but the offset would work on an S10.
            almost all RWD GM's were the same bolt battern except Caddy's, some had some huge pattern.
            Newer Fbodies have a very similar offset to the FWD cars although the bolt pattern is different.
              what you saw was GN/GTA crosslaces - they fit the S10's
