More Electrical problems, chapter 1,395.
  • More Electrical problems, chapter 1,395.
    Vehicle- 1992 Lumina with everybodies favorite 3.4 DOHC. NO Stereo, amps or any add on electrical equipment.
    Symptoms- Battery light is on along with Abs light. Voltage guage is at the first guage mark after 8 or slightly lower. This drops to 8 in 10-15 minutes. Vehicle dies. battery is dead. Voltage does not change with rpm. No accesories like radio or a/c are on at anytime. Only signal lights and brake lights when needed. Headlights are off.
    I have replaced the alternator with a known good unit. I had this unit tested by people I trust at O'reillys Auto parts. The original unit did not pass. Fried stator. The unit I installed did pass.
    Now, the car has been sitting for at least a year if not longer. I know the battery is weak, but it will hold a charge after the battery charger is put on it.
    Before you say replace the battery, Why would it hold a charge off the charger but die in the car when the Alt. tested good ? The large power wire on the alt. is in excellent shape, the battery cables look good, the grounds are clean and no wiring is pinched.
    Where do I go from here? I know I should replace the battery, But I have the feeling this will not fix the problem. I have replaced the engine (last week) and this problem is confusing me. I am not an electrical genius and have a hard time with problems like this. normally if a battery is weak it will die sitting overnight. Not the case here. If the battery starts the car at night, it will start 10 hours later. I don' t think a junk battery will hold a charge that long. MAybe I am wrong. Is the guage in the car measuring voltage from the Alternator or from the battery? Could a bad battery cause the car to die after 15 minutes of stop-n-go run time? Or is alt. #2 faulty also? Any help or sugestions are greatly appreciated.
    If it\'s fun, it\'s probably illegal and if it\'s illegal I\'m probably doing it.
    92 Lumina Z-34
    89 Cavalier Z-24
    83 Camaro Z-28
