symptoms of a bad cat converter
  • symptoms of a bad cat converter
    wat are some symptoms of a bad cat converter?
    the car runs but it hesistates from a stop, exhaust smells like rotten eggs
    How can i check for a bad cat
    \"Pree\" - 93 Grand Prix SE - 3.4L Twin Dual Cam
    - FFP UD Pulley - FFP Chip - 8mm Taylor Wires
    - 160* T/stat - Dual 40 Series Flowmasters
    - Hi-Flo Cat
    15.2@95mph - GTECH P/B
    http://home.rgv.rr.com/tjperformance/Cap0005.mpg
    If you tap it and it sounds hollow, or it rattles, then its bad. Symptoms include lack of power and hesitation.
      It will also rattle when running, and it is very noticeable... probably more so on mine because of my flows... run it while it's on a lift (if available) and listen to it, you should be able to hear the rattle.
      --Rob
        sometimes they just clog up and dont break up. You would see it heating up and glowing red most likely if that is the case.
          Ben's right, I've seen them heat up red too, extremely red. Don't get a clogged cat converter confused with a bad O2 Sensor. A bad sensor may eventually cause a clogged converter. I always replace the sensor when I replace a cat converter. If you have 2 O2 sensors, then I'm not so sure if you need to replace one or both or either.
          Stan
          1994 White Cutlass Supreme Convertible 3.4 DOHC
          Add Ons: Overhead Display, Digital Dash, Trip Computer
            Yeah, the one in the 91 sounds like someone filled it with marbles...
              the best way to tell if your cat is bad, is to get an thermometer (perforably infrared). Then take the temp at the front and then the rear of the cat. compare the temps. you should be about 100degrees higher in the rear than in the front. check it, the temps don't lie!!!!
