I just recently got a 93 z34 with no power in 4th have to start out in 2 toget to speed than put it in od it has 4t60-e. Also it wont rev up over 3500 rpm in park or nutrel and has a mis. Any info will help i dont know where to start. i dont know any thing about this engine its nothing like my 79 gmc. thanks in advance
new to site please help many problems need info and advice
There is a rev limiter in p/n so thats how its supposed to be. Not sure what is up with the power issue other than it sounds like it could be many different items right now. Have you done a compression check and checked your fuel pressure? Just a starting point really.
It shouldn't start out in 2nd. Are you saying that you have to put the gear selector into 2 to keep it from going into 3rd? Does it lack power all the time? Im not quite sure what is going on.Ben
when i first got the car i put it up on jack stands and had to plug in 2 spark plug wires back into the coil well im not shure what its called could this cause any other problems93 z34
87 t-bird turbo coup
79 gmc pk up
98 explore sport
74 harley sportster baskit
so its normal to only rev to 3500 in p/n. im going to take it to the shop and have them put it on the putter to see what all is wrong next week till then i guss ill just tinker a little and see what happens i heard that if it would go into every gear that it wasnt the tranny when i had it up on stands it went into every geear and spun the tiers. thanks for the help93 z34
79 gmc pk up
98 explore sport
after finding two plug wires off, the FIRST thing to do would be a very thorough once or twice over the tranny and engine to make sure there are no sensors disconnected. Been awhile since I fucked with the 4t60-E, but some trannies go into "safe" mode if all the data isnt adding up and will shift strait off of line pressure.2004 Grand Am GT 3400 ... I had the right to remain silent, I just didn't have the ability.(Ron White)
Sounds like a boned tranny. Even in "safe mode" the transmission should move in selector "D," even if it will lock into 2nd gear for all selected ranges. Does the OD light blink at you?
If 1st is slipping, you've very likely got a burnt tranny (1st and 3rd are the ones that go on a 3-spd... I'd have to check and see which sun gear pair are common to this tranny). Fortunately, you should be able to find any number of useable replacements in the junkyard.
There are two slightly less disturbing possibilities. Make ABSOLUTELY SURE that your tranny fluid level is right (start car, idle for about a minute, then with foot on break put the selector in EVERY position for at least 15 seconds each). Check the oil while in Park and running. Low tranny fluid will make the trans slip. Also, it IS possible it's just a plugged valve body. Doubtful, though. If you have enough gunk to plug that mother up, you've got any number of other problems.
Otherwise, hard luck, mate. If you've never changed a tranny yourself, it sucks... But it's doable if you get the right tools. Just follow the directions in the shop manual
I apritiate the comments. When I was under the car there was a wire unpluged onthe passenger side by the tranny i pluged it in but it looked like it would go on either way. I changed the filter and fluid in the tranny.
It still seems the same way but a little bit better but it shudders real bad on accel. Where as befor it just wouldnt go. The car will drive with the selector in every gear with no power except reverseand i dont think it is shifting. Thanks again you all have been alot of help. The only front weel drive tranny i have changed was in a 90 somthing ford mini van but it just droped out the bottem. From what i understand it is a little more difficult with this car.
93 z34
79 gmc pk up
98 explore sport
