Okay, so it IS cam timing. Just needed to get you in here. I read teh writeup and followed it as good as I could. Here's what I did:
1: Removed Engine from vehicle
2: Removed side covers
3: Removed Timing belt, tensioner, ilders, tensioner actuator.
4: Got #1 Cylinder to TDC on the Exhaust stroke(or whatever, the Harmonic Balancer mark lined up)
5: Installed Cam Flat Hold Down Tools
6: Installed Timing belt and tensioners and actuator and all that
7: Removed Cam Flat Tools
8: Rotated engine ten times while increasing tension on belt
9: Checked Marks
10: Reinstalled Engine
11: Replaced Alternator with engine in just to prove I'm a hardass.
The marks all line up well, and there's lots of tension on the belt. Did I miss anything? Is the car going to explode when I try to start it?
9: Checked Marks
