My Z just started stalling for no reason and will not crank back up until it cools off. Broke out the factory manual and started troubleshooting for a no start condition. Fuel pressure at 43 psi and fire at all plugs. Continued down the chart and connected a testlight to B+ and probed ckt 467 ( injector driver). Cranked engine and test light blinked bright twice, blinked dim twice, and quit blinking alltogether. Does this sound like a bad circuit board in the ecm? After engine cools off, ckt 467 blinks fine until engine gets hot again.
faulty ecm or not
IF its a code 15 that coolant temp sensor ( low temperature)1991 Grand Prix STE
3.4 DOHC
1 of 792 Produced
Extensive Mods Done
1991 Lumina Z34
3.4 DOHC
Getrag 284 5spd
1 of 30
To be sure the trouble light is reading right just turn the key on and using a small piece of wire jump the "A" and "B" connector on the Diagnostic Plug and read the flashes from the CHECK ENGINE LIGHT.1991 Grand Prix STE
3.4 DOHC
1 of 792 Produced
Extensive Mods Done
1991 Lumina Z34
3.4 DOHC
Getrag 284 5spd
1 of 30
Shorted to itself no, shorted to chassis ground it can as the ECM is ground fault protected. On a chassis ground the voltage coming from that are unfiltered and may spike enough voltage to burn out the resistor in the ecm. Nine volts is enough to burn out that resistor.I am back
Mechanical/Service Technican
