I need a water pump pulley for my '92 LQ1. Found one!
  • I need a water pump pulley for my '92 LQ1. Found one!
    Found one!
    yep. $10.00+shipping. PM with your zip and i'll give you a total.
    1997 Z34 Monte,: testing 4 exh cam\'s, RSM STB, K&N, Eagle077 245/40/ZR18 Nitto Extreme
      Water pump pulley
      Thanks, but I already came up with one.
        RE: Water pump pulley
        and it deserved telling us you needed one.
        I am back
        Mechanical/Service Technican
          Re: RE: Water pump pulley
          This post is also in the wrong section.
            What?
              RE: Re: RE: Water pump pulley
              It is a common part... not rare at all.
              About as common for the years as are cooling fans..
              I am back
                Re: RE: Re: RE: Water pump pulley
                Yeah, I discovered that while I was looking for one.
