oil in spark plug hole
  • oil in spark plug hole
    well the other day I noticed a miss possibly but def a knock or tapping. I was looking around today and noticed that there is oil in my spark plug holes the front three at least i didnt get a change to try and pull the back ones. not alot of oil but I would think more than should be there, mean more than none. So any ideas wat I have to try and fix or at least some things to check.
    thanks Joel
    Replace your valve cover gasket.
      Either that, or the cam carrier gasket has sprung a leak. But first definatly change the valve cover O-Ring gaskets.
        ok thanks, so would that make the tapping , and the valve cover gasket, not real sure where that is, it rings a bell but I dunno the cam carrier is not prob.
