O2 Sensor
  • O2 Sensor
    This may sound stupid but how in the world do you get to and remove the O2 sensor. Thanks.
    92 Lumina euro 3.4 DOHC 139,XXX miles
    I pulled the engine......
    But I think you can get a slotted socket that should work.
    Also if you cut the wires to the old O2 sensor you can use a combination of PB Blast, 4 extensions, a swivel adapter, and a regular deep socket (21mm?).
    You can get to it from the top if you pull the engine forward or you can remove some shields from the downpipe and get at it that way. In any case it is hard to remove.
    95 MC Z34 Black
      thanks ill give that a try
