95 GP GTP water pump
  • 95 GP GTP water pump
    Anyone have a how-to to replace the water pump? Is it just as easy as unbolting the old one and installing the new one or am I looking at a crap load more work?
    Thanks,
    Matt
    -Matt
    1995 Pontiac Grand Prix GTP
    1: if you dont want to spill coolant drain the radiator some
    2: loosen the 4 bolts on the water pump pulley
    3: remove the serpentine belt
    4: remove the 4 pulley bolts and pulley
    5: remove the 5 water pump bolts and pull the pump out
    and that is it.
      Its really easy with an impact...gun is a bit deep so an impact wrench would be ideal. Its not hard, just make sure you scrape the gasket off and put a new one in.
