e-brake cable
  • e-brake cable
    does anyone know what holds up the e-brake cable because mine hangs down with the e-brake off between the middle of the driver door and the rear door. i looked and didnt see anything that would hold it up and it goes up when i apply the e-brake.
    92 Lumina euro 3.4 DOHC 139,XXX miles
    Your cable needs adjusting. Crawl underneath and around by the door you will see an adjustment screw. Just turn it a few until it tightens up. Your rear brake pads could be getting low also that contributes also.
    '93 Cutlass Ragtop LQ-1 -- Semi-retired over winters
    '06 Dodge Magnum SXT 3.5L -- My Daily Driver
