Cam TSB
  • Cam TSB
    Anyone know the TSB # for the camshafts. What was it about? I think it was cam oiling problem. Dont remember right off.
    1997 Z34 Monte,: testing 4 exh cam\'s, RSM STB, K&N, Eagle077 245/40/ZR18 Nitto Extreme
    RE: Cam TSB
    http://60degreev6.com/TSB/TSB03-DOHC.html Cam Timing
    http://60degreev6.com/TSB/TSB01-DOHC.html Cam Thrust Plate Oiling
    Until I get them up on the site as links, you can access the rest of the DOHC TSBs by just changing the number following the TSB in the links. There are 10 of them.
