stalling
  • stalling
    my car seems to just shut off if i try to use somthing electrical sometimes. an example is a couple days ago i was in my driveway idleing and had just put up the back windows and hit the button for the front window and the motor died. it started right back up though. it also did it about a week ago when i went to turn on the radiator fan (long story and im gettin to fix it) and it shut off as soon as i hit the switch. i thought it might be that phantom stalling but the motor wasnt really under load. what could it be?
    92 Lumina euro 3.4 DOHC 139,XXX miles
    That is completely normal for 91-93 DOHC. With the 5-speed they will even stall when slowing down to a red light, which is really dangerous. The problem is the fuel injectors, and new ones will fix it. Or you can put injectors from the 94-97 DOHC, this will also fix it.
      so the newer gen injectors will go on my car and solve the problem with no modifications?
        YUP
        I am back
        Mechanical/Service Technican
