problem may be fixed
  • problem may be fixed
    car is in the shop the mechanic told me that the fuel pump is bad that it not putting out enough pressure said pressure at the tank was 12 psi so they will install a new one. i put in 2 fuel pump my self that has been fuck up from 2 different parts stores. it just amazes me makes me wonder if it some thing clogged in my fuel system like some where in the sending unit assembly? i hope the shop check that any way its there problem now will cost about 350 bucks that i will be out of but if this fixes my problem it well be worth it. because i was getting really pissed off with this car. so we will see what happens when they say the car is ready.
    I thought you said you were getting 40psi at the fuel rail?
      Did you replace the wire harness or just the pump?
      95 MC Z34 Black
