fuel problem
  • fuel problem
    ok why am i not getting fuel up to the fuel rail and injectors? fuel pump working. installed 2nd new pump. ok the vac port where the pressure reg line and trans line hook up is that pressure air (blow ) or vac air (suck) because if its blow air then its ok but if its suck air then somthing is wrong and i mean f--k up because its blowing big time. any help anyone? this is a 94 gtp 3.4 getting ready to go to the shop if i cant get the help here and whats f--k up i am a mechanic. so you know that iam iam stumped
    RE: fuel problem
    If you aren't getting fuel to the rail, the regulator is not going to be an issue. You should be able to put a vacuum gauge on the regulator itself and hold pressure. If not, its shot. As for the fuel not getting to the rail, is the line clogged up or something? Ive never heard of a no fuel situation. Are you sure the pump is working and you have gas in the car?
      RE: fuel problem
      Clogged fuel filter perhaps?
      '93 Cutlass Ragtop LQ-1 -- Semi-retired over winters
      '06 Dodge Magnum SXT 3.5L -- My Daily Driver
