head install
  • head install
    the book says to clean the block deck with laquor thinner or acetone prior to gasket to head install. Can I just clean it with deisel?
    the block was cleaned at the machine shop, but I put a light coat of oil on exposed metal surfaces. I assume that the deck needs to be clean and dry, maybe just a shop rag will do the trick.
    pistons went in without a hitch.
    95 MC Z34 Black
    RE: head install
    The laquer thinner or acetone will evaporate, leaving the block surface clean. The deisel will leave behind an oily residue, which will hurt gasket sealing. I just use brake cleaner....it works the same as the thinner or acetone.
    Marty
    '99 Z-28 - Weekend Driver
    '84 X-11 - Time and Money Pit
    Quote of the week:
    Originally posted by Aaron
      RE: head install
      thanks
      95 MC Z34 Black
