3.4 Tensioner Pulley - Good or No Good?
  • 3.4 Tensioner Pulley - Good or No Good?
    I'm trying to fix a timing issue with my 94 3.4L DOHC.
    I pulled up a Youtube video where the guy said if you can hear noise in the tensioner pulley after you take it off and shake it, it needs replaced. After I took mine off the timing belt today I shook it and whalla I could hear a slight bearing noise inside it is best I can describe; it wasn't loud I could just hear a slight metal noise. Anyone know if this is acceptable or does it need replaced? I just don't need to throw any more unnecessary parts at this thing.
    Also, anyone know what a bad tensioner actuator would look like?
    Thanks!
    If it makes any noise, I would replace it. At the point you have the engine at now (torn down) it's worth the time and $$$ not to end up stranded somewhere. As far as the actuator, if you can't turn the screw in the back in, or the boot is ripped I would replace it. The screw in the back should turn fairly easy besides the spring resistance. If it doesn't, it's binding inside and could bind in such a way as to not remove slack in the belt as it stretches.
      Yes that does make sense! Thanks for the input!
        You are very welcome, and by the way, welcome to the site!
          Thanks man!!! Purchased new pulley and putting it all back together soon!
            Just to add for anyone else too..
            Don't forget to set the tension of the pulley by applying (20 ft. Lbs iirc) torque to the roller (@ the square peg) after you pull the keeper pin out of the tensioner...
