ignition replacment
  • Question : ignition replacment
    gotta replacement the ignition / lock cylinder in my 92 z34.
    Will i have to pull the steering wheel to replace it? Gonna go get the ignition from autozone this weekend, and if so rent the wheel puller.
    Which are you replacing--the lock cylinder or the ignition switch?
      cylinder
        You'll be pulling the steering wheel. I'm thinking you'll need to pull the anti-theft lock plate, too. Another special tool.
        Don't forget to take the new cylinder to a locksmith to have it re-keyed to match your old key--if you care.
          ill get a write up in the am
