Is the 95 olds 3.4 DOHC an interference fit motor?
  • Question : Is the 95 olds 3.4 DOHC an interference fit motor?
    Hello everyone
    From what I can gather the 96 3.4 DOHC is an interference motor and not the prior 3.4DOHC engines.
    Is that an accurate statement?
    The belt snapped on my 95 olds convertable- while on the hwy. I'm trying to save it's life with just a new belt and probably pulleys. Can't sink a lot into it, but it was running like a champ and the car just looks too good to trash. If it's not an interference motor I think I'll get the parts. Any help/direction would be appreciated.
    there are LQ1s that snap belts at almost any RPM and still live with no bent valves.
    seems to be more of a random chance than anything. GM however, does not specify if any of the LQ1s are interference motors....
      I have an old GM training manual on the then new LQ1 that says its non-interference. I suppose that stance could have changed in 96 or whatever year received different pistons.
      Jesse M.
      3x 1990 Turbo Grand Prix
      1987 Monte Carlo SS Aerocoupe
        Might be hope yet.
        I'll check and see exactly what generation motor is in there. If I can fix the oil leak and replace the belt for a reasonable cost- I'd like to try it. Just hate to find out more work needs to be done once it's apart. Can't $afford$ any surprises.
        If I can find a crate motor or a rebuilt reasonable enough, I'd rather go that route-depending on the cost. Anyone know of any dealerships with one as idle inventory?
        Thanks for the info guys! - anyone with more info- I'd appreciate all I can get.
          Oh I'd definitely try my luck on this engine. They do seem to occasionally bend valves, but the majority of the time they are fine.
          Jesse M.
