Front brake disc
  • Front brake disc
    My front disc have a lot of play,as in lots of movement around the wheel studs,is this normal?I always thought that the disc should be snug,are they just kept in place by the calipers and studs?
    Only until you bolt the wheel down, and then the wheel sandwiches the disc between it and the hub.
      Thanks for the quick answer,thats what i was also thinking,guess i may have to do a front struts change as i am getting a clunking noise like shocks bottoming out when going over bumps and also car pulls to the right.
        Fix the struts and get the vehicle aligned???
          darn those pesky front struts
