We were out in Jersey yesterday and were accelerating off an on ramp. My girlfriend was driving my 1995 Monte Carlo Z34 3.4L DOHC V6, so she wasn't hammering on it,... I'd figure 40% throttle. The car revved up all of a sudden and then just shut down. I couldn't get it started but I had an idea of where this was headed. No metallic sounds before the engine shut down, no smoke, no big bang. I had to call a Tow Truck which I never thought I'd have to do with this car. Got the car home and took a look at it this morning in the rain. This is what I found.
The timing belt is shredded, and when I attempt to turn the engine over the belt doesn't move, but there is still tension on the cams which leads me to believe it broke down by the crank. This is bad because normally the cams would all close and the valves would be saved, but in this case, the valves are all still open so this would leave room for the valves to collide with the pistons. Supposedly this is a Non-interference engine. But at TDC with the valves at full extension, there is only .010 clearance between both. I was reading online about other people who have had bent valves after a timing belt break.
Then there's a second issue that's got me even more concerned. I pulled all the spark plug wires and they were all normal except one. The rear bank, on the left hand side.... I pulled out and the plug wire itself was COATED in oil, it was dripping off. When I went to pull the plug, and i slid my socket down into the hole it slouched around in there before locking onto the spark plug. I can't figure out what would cause this. I am wondering if this is a pre-existing problem I never noticed or a result of the belt breaking (damage). I would like to do a compression test. How else can I check this motor over to make sure there is no valve or piston damage before pouring $500 worth of work into it? I need some creative ideas.
So, ya think i'm screwed?
Dan
Dan
