How to do a rear main seal?
  • Question : How to do a rear main seal?
    I got one in my conversion kit. I feel its better to do it while the engines out and before it goes bad. How do you change it? Do I have to pull the cap?
    no you dont have to pull the cap.. If you dont have a seal puller just be careful with a screwdriver and dont nick up the crank. Pry it out and put the new one in.. Dont forget grease.. It's just like changing any other seal basically..
    Robert
    New Rebuilt 3100
    New Rebuilt 4T60-E
    Exhaust
    Drilled/Slotted Rotors
    White
    3" Magnaflow Catback
    90 Pontiac Turbo Grand Prix
    5 Speed Swapped
    127,000
    Spec Stage 3 Clutch
    230,000 mile Getrag 282
    Emissions Deleted
    Brand new Engine 1,000 Miles
    Fully Custom Built car
      what grease? I never used grease on any other seals. And dont i need rtv for this one?
        i use grease on the inside of the seal so it sllides in real nice and doesnt tear or damage it plus it helps lube it.. when i did my rear main i didnt use any rtv but it wouldn't hurt to put it on the outside of the seal for extra protection..
        Robert
        New Rebuilt 3100
        New Rebuilt 4T60-E
        Exhaust
        White
        5 Speed Swapped
        127,000
        Spec Stage 3 Clutch
        Emissions Deleted
          Actually, I just did my rear main and used oil on the seal.... Later on I found a GM Service Bulletin on the new seal and they said use NO oil or grease to install, keep it dry... I can't see a problem with lubing it and I hope it holds!!! I'll find the file and post it....
          Tom
            if the engine is nice and old then you should pull the cap and re RTV the cap and the block mating surface.Then you can replace the seal at that time. Otherwise just pull the seal and repalce it.
            Lorenzo
              The motor has 120k miles on it, I think im just gona rtv the cap and install it dry. I mean old ones are dry..
