Proper Compression #'s???
  • Proper Compression #'s???
    what is the proper compression on the 3.4L DOHC?
    gonna check for compression tommarow, Just curious as to what the compression spec's should be?
    Thanks
    Usually anything above 150 is ok. You want the numbers to be within 10% between all cylinders. So if your lowest cylinder was 150psi, then you shouldn't have any cylinder higher than 165psi.
      cool, thanks man!
      Shane "RedZMonte"
      1992 Lumina Z34-VIRGIN (RIP)
      1992 L67 Lumina Z34 (SOLD)
      1990 Turbo Grand Prix (SOLD)
        they should run about 170-190 psi
        Lorenzo
