help car barely runs...
  • help car barely runs...
    my 3.4 v6 is barely starting, and when it does it is clicking like crazy(sounds liek popcorn popping) and i would like to know what it is, it was running a few days ago when my dad was driving it and it ran fine now this, i have been told it could be an oil leak from a plug where a distributor should go into the block because when i put in more oil it seems to die down and then come back later
    Do you have an oil pressure gauge and if so what does it read? I'm not too hopeful....
    Lorenzo
      Check and make sure you don't have spark plug bown out. Thats the closest sound to popcorn poping that I can think of. If some one put plugs in with the heads hot at sometime or another it's easy to destroy the threads.
      http://www.cardomain.com/id/toms92gp
      http://www.nightrydas.com/theprix.htm
        well thanks for the ideas but its too late, this morning it shot a rod through the block on the way to school
          Ouch, that sucks..
          Sounds like an oil pressure gauge and watching your oil levels should be on your list of things to do when you get another car!
            yeah what is weird too is that the oil pressure gauge said it was fine all the gauges were fine, and then all that happened
