Missing some things?
  • Missing some things?
    Hello I am rebuilding a basket case 93 Z34 in my shop, and most of the engines top end came in a box in the trunk. After inventory I found I need the intake hose. Have been able to reassemble most of it, I also have an errant two wire connector under the throttle body that I cannot find a home for. Any idea's here?? Curt
    \"Experimentation\" the mark of a verteran weekend garage warrior
    that wire is probably for the coolant temp sensor, if you look hard enough you will see it under the throttle body in the lower intake manifold,on the side 90* from the thermostat.
    Jake
      Ok thanks for the help I found the CTS missing!! replaced it and found the connector wires too short, so I added wire. The dang thing is still a no start.... working on that too! It had been driven into water and flooded out the engine and maybe the ECM. One thing at a time.....many thanks Curt
