95 Monte oil usage
  • 95 Monte oil usage
    Hi all. I just inherited my moms old car, its a 95 Monte Z34. She bought this car new, and it only has 61000 miles on it. Ive been driving it back and forth to work for about three months now, and it runs absolutely perfect. The only problem that im having is its using a quart of oil every 1000 miles. I know all the service history on the car, timing belt, intake gaskets etc. Is there anything that is common on these that would make them burn oil?? i know it doesnt leak, my driveway is clean as can be. Any help would be appreciated. Thanks
    1. Valve Stem seals
    Have someone look at the tailpipe when you start it up in the morning (after it has sat for 8 hours).....any smoke?
    2. Oil Control Rings
    You most likely will not see the smoke coming out...but an emission test could find it.
    Note - If any of the rings have stuck...this too...might change oil...run it 1,000 miles, and then change it again...fat chance...
      I highly doubt rings due to the low mileage and service history of the car, unless rings were a COMMON problem on the 3.4 . And no it doesnt smoke at startup.
        I ...doubt rings
        2007 - 1995 = 12 Years
        61,000 / 12 years = 5083.3 miles/year
        Was the oil changed every three months? How long did it sit with "sludge" in it? Rings can stick to the piston...and cause this...but
        How far is work from your home...does the engine get up to full temperature?
        All engines will burn some oil...all...but if you do a lot of Start/Stop in short duration...then rings will not be fully expanded, and you can use more oil.
        Btw, I've got a 82 Impalla with 200,000+ on it, and it uses a quart in 2,000 miles...but my shortest Start/Stop is like 5 miles...normally 13+.
          My 1992 Lumina Z34 with 131,000 miles on it uses just as much oil in the same amount of time.
          My vote is Valve Guides. I had recently done the upper and lower intake manifold gaskets and noticed build-up on my valves.
          It is common with these engines to go through the valve guides rather quickly.
          Now its pricing the fix thats the hard part.
          1992 Lumina Z34: Artic White on Gray -Auto
          1987 Porsche 944: Slate Gray Metallic on Burgandy- Manual (Possibly for sale)
            Yes...but 12 year old vehicle...Valve Stem Seals become defective...so on intake stroke, it sucks oil through.
            I put together a 3.8 motor from two different motors...with some 100,000+ miles on each...I installed good intake valve-stem seals...passed Denver Emission Testing five years later, and with some 60,000 miles later. [About 160,000 miles on heads without R&R).
            Yes, one may have to clean up valves/etc when doing head work...but having good intake valve-stem seals is a must, as one company says:
            Enginetech umbrella valve stem seals are so unique...they're patented
            You can virtually eliminate valve stem seal-related oil consumption comebacks with the Rebuilder's Valve Stem Seal, from Enginetech. It makes all other seals obsolete!
            Positive Seals
            Enginetech's positive seals solve the problems common to most other guide-mounted seals which starve the guide of oil at first, leading to premature wear. That, in turn, causes oil to flood through the guides.
            Enginetech uses a spring-loaded state-of-the art Viton lip to meter oil precisely from the first day. This fluoroelastomer material is extremely resistant to heat, oil additives and abrasion.
              What's the Verdict?
                well im not gonna tear it apart, it was a free car. No point in me taking it apart, that would be just silly. Ill wait till something rears its ugly head. To me oil is pretty cheap.
                  Maybe several quick oil change/filters every 1,000 miles might be tried.
                  Engines need to come up to temperature....if your thermostat is running cold, this too could be related...know anyone with a scan tool?
                  If just short trips are the norm, this may be the reason why higher usage.
                    Nah, i put 50 miles on it a day. Ill hook it to the scanner and see what the actual operating temp is. Otherwise i think im gonna drive it and see what happens
                      nobody hear thinks its the Dis O-Ring ???
                      1997 Chevrolet Camaro 30th Anniversary 5Speed.
                      3800 V6 (i know its not a 60degree)
                      stock for now
                      1993 Special Edtion/GTP
                      3.4 DOHC V6 LQ1 SOLD!
                      CHIPED,CAI,EXHAUST 2 1/2 SUMMIT TURBO MUFFLERS & NO CAT,,AC DELCO RAPID FIRE PLUGS,
                      180 STAT. FUTURE MODS,50,000v COILS,FFP PULLEY,FFP DOGBONE!
                      VIDEO http://vids.myspace.com/index.cfm?fu...oid=2020589230
                        Already changed that..............
                          From what he describes, no oil leaks...then the motor is burning it...which way, I don't know.
                            Here you go...get the full details: THE 3.4 DOHC 24 VALVE
                            One more area to inspect often is the oil pump drive. This is located on the
                            rear (LH) of the motor, under the throttlebody. While almost impossible to
                            see from up top, if it starts leaking oil it will leak oil VERY FAST!!! The oil
                            pump drive is a leftover from the 2.8/3.1 design. It is where the Distributor
                            used to go. With the advent of DIS, the dist is gone, but the gears and oil
                            pump remain. This is sealed with an O-ring alone. On the other side, is a
                            pressurized gallery. When (not if) the O-ring breaks, engine oil will leak
                            under whatever oil pressure is available. In extreme cases, a quart every
                            100 miles is possible. More bad news: to replace the .29 O-ring, the upper
                            half of the motor must come off. Replacement requires cylinder head removal.
                            Only good part is if this happens, you can replace a bunch of other parts with
                            virtually no labor...it's already apart.
                              Change the PCV valve that sometime helps.
