code 32 EGR?
  • code 32 EGR?
    ok so im getting a code 32 a its that EGR code and well i was wondering if anyone knew what it might be where it would be in the car and how could i fix it? i would prefer to not have to take it to the mechanic if i dont have to
    its the 3.4L
      Sounds like a clogged EGR is the cause. Take it off and clean it and the passage into the intake manifold. It usually clogs with carbon and then the computer detects there is no longer flow and sets the code. Use some brake cleaner or throttle body cleaner.
        ok thanx but where is it?
          On a DOHC I couldn't tell you. But it will look like a 3 black tower shaped thing for that year.
            humm i see ill keep an eye out for it but if theres anyone who might know where it is located please let me know
              Its on the back of the intake manifold on the driver side. It usually has a funny looking black circular cover on it that looks sort of like the bell of a jellyfish. If the cover is missing there are 3 black EGR solenoids visible.
                I have the same code and I've cleaned it several times.
                For me I might havbe to replace it or go the better route and get a chip to delete it.
                Unless someone knows a better way???
                1992 Lumina Z34: Artic White on Gray -Auto
                1987 Porsche 944: Slate Gray Metallic on Burgandy- Manual (Possibly for sale)
                  I have actually taken mine off and disassembled it. It's easy to do. You can clean it up really nice if you do this. Just clean out the three holes and the pintels on springs. Be careful to put them back in the exact passages they come out of when reassembling.
                  If you do that along with cleaning the passage you should be ok unless it is some electronic malfunction in the EGR valve itself.
                  '93 Cutlass Ragtop LQ-1 -- Semi-retired over winters
                  '06 Dodge Magnum SXT 3.5L -- My Daily Driver
