284 5-speed oil leak
  • 284 5-speed oil leak
    Looks like it's coming from the driver's side diff where the halfshaft attaches to the stub axle. Is that a seal that can be replaced with a 282 part? Also, do the output shaft support bearings for the 282 work on 284's?
    92 ASC GTP - 3.4 5sp, HUD, DIC, AQ9's
    88 Fiero GTs - L32 3.4 5sp & ZZ430 5.7 SBC V8 5sp (the twins) L32 -> LQ1 swap is underway
    6sp LS1 Corvette Roadster (parts getter)
    '99 Expedition (tow truck)
    '09 G8 (new toy)
    are you sure its oil and not synchromesh fluid?
      Same thing. Point is it's leaking fluid, doesn't matter what kind.
      '09 G8 (new toy)
        gm part number is 14092900 (discontinued)
        you can order some and wait or call up a parts store and see if they can interchange them. i think theres an a/m pn in one of the recent trans section threads. i found some seals from another tranny that worked, but im not sure what they were. they actually were a little tighter than the gm ones. i think they were actually from like a 60.
        edit: found the post but there was no number in it.
        91 GTP HM-284 GONE
        96 Special Edition LQ1/4T60E GONE
        98 Spawn of Satan (L67 Regal)
        87 V10 SM-465/Mild 350
        06 Cobalt SS/SC GONE
          Using that I found AC Delco part number 24202835 Drive Shaft Seal which says it's for the 3- and 4-speed automatics, though it is also listed under Manual Transmission. If it's the same part number that'd be great, as it seems to be pretty commonly available. There's also a Timken part number 3543 listed as an Output Shaft Seal.
          '09 G8 (new toy)
            The part number you need to get from the dealer should say that's its discontinued from GM but that you can get them from VPI. I had to get two of them earlier this year, they have about 430 left.
              Last time I called VPI they wanted $500 for a $50 part!! They're not my friends anymore.
              '09 G8 (new toy)
                Even if the output shaft support bearings work on the 284, I wouldn't use them. The surface they ride on is NOT hardened. The axle surface gets galled.
