Weird Idle
  • Weird Idle
    When my cars cold the idle goes up and down constantly. No any more than 200 rpm but its definitely noticeable. What could be causing this?
    A vacuum leak would do that. Check your lower intake manifold gasket.
    Notorious for going bad on these motors.
    '93 Cutlass Ragtop LQ-1 -- Semi-retired over winters
    '06 Dodge Magnum SXT 3.5L -- My Daily Driver
      Your kidding.. All the gaskets have just been changed less than 5k miles ago. But I did have a coolant leak and a shop said it was probably my headgasket, they put stopleak in the coolant and it stoped.. This time i'm gona do the gaskets myself..
        I also have alot of cracked vacuum lines so i'm gona try replacing them first.
