problem with rpms
  • problem with rpms
    hey guys looking for some help i have a 94 gtp 3.4 liter . when i am at 50-60 mph and holding, my rpm are at 2krpms my rpms starts to decel 2000-1500 then back up 2000 it will keep doing this until i give it more gas you can hear and feel the decel in the engine anyone have any idea what would be causing this? the only thing that i found that i had a bad pressure regulator. thanks for any support
    idel problems
    can i get some help i posted on 01-27-2007 please i need some answers thanks
      Sounds like the TCC is engaging and disengaging constantly. Could just be a loose connection at the tranny (doubtful) or the TCC solenoid acting up.
        You may have a bad vacuum diaphram, pull the vac line going to the tranny plug both ends and test drive it.
        I am back
        Mechanical/Service Technican
          Are there any check engine lights on if si that will help you alot?
            it sounds like it could be a bad throttle position sensor or something but it would also act up at idle and you would notice a hesitation off the line as well
