Make 3.4 Thermostat Replacement Easier?
  • Make 3.4 Thermostat Replacement Easier?
    While tearing down my 3.4 Litre for intake gaskets and timing belt replacement,
    I can see that the lower thermostat (T/S) bolt is near impossible to remove. This is due to a rigid coolant line support strap also being held by the same lower bolt.
    I am changing the T/S with the best one AutoZone had (bought a while ago) while I have the engine apart now.
    But looking toward the future, is there any modification to that strap/coolant line that I can do now to make it easier to replace the T/S the next time?
    I'm thinking of grinding off that strap and fabbing up a single hole wrap-around strap that would attach to the same bolt that would be removeable.
    Anybody got a better idea?
    jogasz28
    ______________
    '68 RS Camaro,
    Project '69 Camaro in the works
    '95 Monte Carlo Z34 loaded,
    '99 Monte Carlo LS
    I just bend it down and bend it up when I am done. Really wasn't hard. Its probably not all that important that you couldn't cut that tab off. I dont think it will go anywhere without it.
      or you can swap in the 96-97 upper intake LOL our Tstats are easy to get at.
        There is room to bend without damaging?
          Get rid of it! hahaha. I did. But now I am swapping to a 96 - 97 setup.
            Yea I did away with it..
            Thinking about a 96-97 top end swap myself..
              I just bent mine all the way over and never bent it back. Its easy to do once you get that tab out of the way.
              http://www.cardomain.com/id/toms92gp
              http://www.nightrydas.com/theprix.htm
